payed my top up
i topped up with 10 euro in dunnes stores shopping centre in mullingar and my credit was accepted and i cant make calls or texts your sincerly martin
You topped up your credit balance but did you then buy membership?
http://community.48months.ie/t5/Most-Popular-Questions/What-is-the-difference-between-membership-and...
