nternet Settings for lg-c360
i have a lg-c360 can anybody help
Any use if you replace the giffgaff settings with the 48 equivalents?
http://community.giffgaff.com/t5/Help-Support/LG-C360-settings-not-working/m-p/4726548#M1608103
Aoifec
Crew
Crew
Hi thomasb23,
Try the settings below and see if they work for your LG C360.
They’re a bit longer than most settings just because of the type of phone you have.
Let me know if this gets your internet up and running.
(1) From the start screen, tap the central navigation key
(2) Tap Settings
(3) Tap Connectivity
(4) Tap Access Points
(5) Tap New Access Point
(6) Under Connection Title, enter 48 Internet
(7) Under Authentication, choose None
(8) Leave Username blank
(9) Leave Password blank
(10) Under APN, enter 48months.liffeytelecom.com
(11) Under MCC, enter 272
(12) Under MNC, enter 11
(13) Tap Done
(14) Tap Back
(15) Tap Internet Access
(16) Tap New Profile
(17) Under Title, enter 48 Internet
(18) Under Use Proxy, choose Off
(19) Scroll down, and under Access point choose 48 internet
(20) Tap Done, and return to the main menu
(21) Tap Settings
(22) Tap Connectivity
(23) Tap Internet Profiles
(24) Tap New Profile
(25) Under Service Name, enter 48 Internet
(26) Under Homepage, enter 48months.liffeytelecom.com
(27) Under Internet Access, select 48 Internet
(28) Tap Done
(29) Choose 48 internet and then Select
(30)Return to the start screen
(31) Switch phone on and off
Yes Settings worked Thanks
