no reception
seamusdoolan
I have no reception on my phone since i came to the isle of man, is there reception on the network over here? or how can i get my phone to work?
Have you tried manually scanning for and connecting to a network over there?
Note that you may need credit to cover the cost of making/receiving calls and sending texts.
I'm not sure if the EU roaming add-ons work there since technically IoM is not part of the EU.
https://www.48months.ie/buy/roaming-packs
