25-01-2014 02:08 PM
Does this mean my phone needs to be unlocked. It suposely was wen I bought a vodafone mobile andw switched to 02, I have a samsung xperia and have applied for the unlock code. My accout wont let me access the move number page and now it says on my account is deactivated and I need to register a new sim. what do I do??
25-01-2014 05:01 PM
26-01-2014 12:09 PM
Is it an iPhone by any chance?
Even when unlocked for use on any network these still require another step syncing with iTunes, sending a UK SMS (which requires at least 25c credit on your account) etc. in order for Apple to activate them on certain carriers (some or all virtual networks such as 48).
26-01-2014 01:38 PM
No, its not an iphone. its a samsung xperia
26-01-2014 02:48 PM - edited 26-01-2014 02:53 PM
Hi again...
(Different makes/model of handset's have their own niggles...
In your case... As initially suggested, Since your account was deactivated, you can choose to start afresh - all that will be changed is the fact you have a new account, support can then see to your sim card and pair it with your account... Or switch your current number on to account if you wished to port over (keep your number) to 48 initially.
However, I would suggest You query with support why your account ended up deactivated... Which is odd... Unless the account was inactive for a length of time...
Did you have any recent Software updates? I'm a Samsung S2 owner myself, but they are known to be unpredictable when unlocked and after updating...especially if unofficially unlocked originally - they can re-lock again...it's happened to a few people who posted on the forum.
26-01-2014 02:56 PM
PS...
Is the 02 sim working in the Samsung still? Can you give it a try?
26-01-2014 03:09 PM
sorry, my mistake I said samsung I meant sony, wasnt thinking. I have a sony experia. Yes i tried that and it works, I still have service with 02, that most mean the transfer never went through??
26-01-2014 03:19 PM
Ah, I did wonder about the xperia part... Didn't recall that model with Samsung...;-)
Had you contacted 48 Support On the deactivation issue...?
Once you loose 02 signal completely the number has ported.
Do not remove your sim before that has occurred!
So is everything on course again?
26-01-2014 03:55 PM
yes, I contacted them. ok I wont. think so.
26-01-2014 04:40 PM
That's good news...
Just to warn you though...
*** Please note: Number transfer hours are 8am to 6pm Mon to Fri, 10am to 4pm Sat and Sun ***
