mms settings for nokia lumia 800
Hi i've tried entering the settings for windows phone that u have on here but when i type in the 634 thingy it doesnt bring up the next step it actually brings u into a diagnostics thing so can u please offer some new steps to getting mms settings thanks
If the settings outlined here
http://community.48months.ie/t5/Need-Help/WINDOWS-7-PHONES/m-p/214#U214
don't work then you might need to log a support request to get 48 to help you with this:
ismisemichael
hi regarding MMS settings on a nokia lumia 800, go to marketplace on your phone and download network set up app. This app will allow you to input the generic settings supplied by 48, then remove sim card, power off phone, replace sim card, power on and your phone will then be able to send picture messages. you may need to get someone to send you a picture message to your phone initally to activate the settings. this procedure worked perfectly for me - good luck with yours
