is calling a 076 area code covered under landline minutes
dodgymickster
Does anyone know if calling northern ireland landline numbers using the (018 or 076 prefixes) get covered under the landlines minutes data (when dialling from the republic of Ireland)? Thanks
Do you mean 018 or 0818 or something else?
0181 (universal access number) are 50c per minute charged to from your cash credit balance.
I don't know if this applies to NI 0181 numbers.
Do you mean 076 numbers or 0761 numbers?
0761 numbers (VoIP?) are covered by your membership/add-on landline minutes allowance but again I don't know if this also applies to NI 076[1] numbers.
http://www.48months.ie/membership-plans/other-call-charges
You might want to contact 48 support and ask them about this - maybe post back if you do get clarification?
As far as I know normally only NI landline numbers dialed using the 048 prefix (rather than 00 44 prefixes) are considered Irish (full island) national numbers and covered by your membership/add-on landline minutes allowances.
http://www.askcomreg.ie/tell_us/calling_northern_ireland___use_the_048_code_to_call_fixed_line_numbe...
