internet
dandj
ive a smasung galaxy iii internet not working data is turned on and all the settings are right and ive still no internet plus my account is upto date please help
Make sure that your settings match these:
MMS Proxy: 10.1.11.19
MMS Port: 8080
MCC: 272
MNC: 11
APN Type: * or default,mms,supl
Are you 100% sure that your current membership has a data allowance balance?
Your online account will clarify or dial *100*8# to check your data balance.
Handy short-codes
Did that work for you?
