Internet
noelle
I havnt had internet in 2 weeks now. The H+ sign is up but if i try to use the internet it says the proxy server isnt working?? I have paid for the internet and now it isnt working! I have checked and double checked all the internet settings and everything is perfect..
You won't be able to use it now as the network's down at the moment!
http://community.48months.ie/t5/Techie-Updates/Network-Outage-06-April/m-p/34190#M2279
Are you sure that your settings are correct?
See here for settings that should work in all cases.
http://community.48months.ie/t5/Need-Help/No-Internet/m-p/34146#M12350
Again you won't see any difference until the network returns.
Did that help?
