internet not conecting
emmalinn2
i have a meizu mx4 and it is not connecting to internet. it is also not on the list of phones on the internet.
Try configuring these settings manually:
MMS Proxy: 10.1.11.19
MMS Port: 8080
MCC: 272
MNC: 11
APN Type: * or default,mms,supl
Did that work for you?
