16-12-2013 04:58 PM
16-12-2013 05:17 PM
16-12-2013 06:01 PM
Try the steps outlined here - these steps are generic and not just for Samsung Galaxy handsets:
16-12-2013 10:11 PM
i have acer z3 can you give me the configuration to get mobile internet?
16-12-2013 10:59 PM
Try the steps outlined in the post that I linked to above in my previous post.
18-12-2013 04:53 PM
18-12-2013 04:59 PM
Not sure what you mean.
Follow the steps in the post that I linked to.
For each step if your particular handset is listed then use that.
If not the skip to the next step.
As far as I can see if you are using an Acer Z3 then the online configurator will not work as the device is not listed.
In that case try the Tweakker APN app from the Play Store. If that doesn't work then try the generic settings applied manually:
(Remember to enable data roaming and maybe reboot after making changes).
If that doesn't work then contact support.
18-12-2013 08:33 PM
hello sorry the internet is still not working. tried to do the steps still not working what do i do.
19-12-2013 10:51 AM
Contact support.
