internet on my phone
olabalyie
I bought the guid and my internet does not work. what code do i need to put into my phone for it to work. My mobile phone is a  samsumg galaxy 4. thank you.
17 REPLIES 17
You need to configure your internet/APN settings.
Try the online configurator - choose the appropriate make and model:
http://48months.tweakker.com
If that doesn't work and you are on Android then download the Tweakker APN app from the Google Play Store over wifi and run it to configure your settings:
If you are using an iPhone then try this:
http://iphone.tweakker.com
If that doesn't work then you will need to configure the settings manually:
Internet Settings
In all cases make sure that you enable data roaming and that you have a data allowance as part of your membership or a data add-on.
Thank you so much. Now all im missing are is my contact list. Dont have ones from my old sim. Any ideas how to retrieve them?😕
If the contacts are stored on the old SIM then put the old SIM in and copy the contacts from the SIM to the phone or, better still, your Google contacts so that they get sync'd/backed up to your Google account.
Something like this:
http://androidadvices.com/import-sim-contacts-android-phone/
Many thanks again for your help. I have so much on today, didnt need this hassle too!
Did that work?
Were you able to retrieve/import your contacts from your old SIM?
sparrow17
Yes I got them down. Think I'm all set now 🙂
Great - glad you got things sorted.
Thanks so much
theronankelly
I have used the tweakker and gotten my internet settings but I only have the E no matter where I am and can't get the H at all. Do you know why that is and how it can be fixed?
