internet not working on iphone4
Hi there, my mobile internet has stop working last month i was thinking that was a problem with network have checked my settings on the phone all correct but nothing loading could you please help to solve it. thanks
hi msm,
if it's any help, i'm on iPhone 4 too. All of my Cellular Data Network Settings are blank
*except* for "MMSC" and "MMS Proxy" in the MMS Section.
MMSC ::
"http://mmc1/servlets/mms"
MMS Proxy ::
"10.1.11.19:8080"
lemme know how this works out for you. (Dont forget to restart the phone after inputting the above details)
Do you have a data allowance as part of your membership or add-on?
Did internet access work before?
Did anything change?
Can you post your settings here for review?
Does everything else work OK - making/receiving calls, sending/receiving texts?
hi msm,
MMSC ::
MMS Proxy ::
"10.1.11.19:8080"
