iPhone 5c
cunna21
Can't find internet settings for my iphone 5c
If the online configure doesn't work and manually configuring it doesn't work then you'll need to contact 48 support for assistance.
See here:
http://tinyurl.com/kys43lv
The iPhone 5C is listed in the online configurator so that should work for it.
http://48months.tweakker.com/choose/Apple
cunna21
No still isn't working
cunna21
Okay cheers
