iPhone 4 3G settings
I have type in all the settings correctly and the 3G will still not work. I also turned on the data roaming and it still hasn't worked. Any ideas?
If you have applied the settings as outlined here
and they still don't work then you might need to log a support request to get 48 to assist you with this:
Not being smart but you presumably do have a data package/add-on?
