iPad 2 cellular not working
Up until 2 days ago my cellular data was working fine, but now it has just stopped entirely.. I have don membership paid for, all cellular settings are in correctly, getting the 3G in the top left hand corner, but absolutely nothing will load.. (Safari/snapchat/Facebook etc). What do I do now as I really need cellular data for my job. Please help ASAP. Thanks
You mean carrier/cellular data is not working?
Are you sure that nothing changed?
No software update, settings changes, sync with iTunes etc.?
Check your settings to make sure that they are still correct.
Use this post as a guide:
