failed to move my number
dixon08
Hi!
I have got a security code yesterday but my number didn't change. I tried to get security code again now but it mentioned that's required field on security code. What should I do???
If it's taking that long then as per this key post you probably need to contact 48 support to see what's holding things up:
How do I keep my old number?
What should I do now? Should I send a request to the crew??
Yes - that's what I said and what the key post above says too....
