dont know what to do
Hi elaine,
There's been a problem moving your number. You'll need to check you've selected the right account type.
For example, have you put in 'prepay unregistered' where it's meant to be 'prepay registered'? If so, you can go back and enter the correct details on the move your number page
And if it isn't this, contact us here & we'll sort you out.
tried to move my number it wont let me move it
Did you try what the message above says?
If so and you still can't get it moved then you'll need to contact 48 support to see if they can help you out:
