data not working on phone
mpmmurray
I've a mobile phone called Lead 1 its an Android 4.4.2 The Internet only works using my house WiFi but not when WiFi is off
6 REPLIES 6
mpmmurray
Data won't work only when WiFi in house is on
mpmmurray
You need to configure your internet/APN settings for the carrier data internet connection to work.
See here:
sino
Hi thanks for your help but this didn't work. The 3G on this phone works with the band 850/2100mhz. Is this compatible with 48. Does anyone know about this? Help!!!
As far as I know 850MHz is not used in Ireland but 2100MHz is.
https://en.wikipedia.org/wiki/Three_Ireland#Radio_frequency_summary
http://www.spectrummonitoring.com/frequencies/#Ireland
http://www.comreg.ie/radio_spectrum/search.541.874.10003.0.rslicensing.html
Are you sure that you followed my post above to configure your internet/APN settings?
Do you definitely have a data allowance as part of your membership or a data add-on?
Did you configure all other settings as advised?
Can you make/receive calls and send/receive texts?
When you are not connected to wifi what does System settings > About phone > Status > SIM status > Mobile network type show?
