confused
pudzy
my 10 euro credit xseaded the 300 min ... so i topped  topped up with 20 euro  but i hasnt kicked in yet...    i dont no way
Topping up your credit balance is not enough
You need to buy a mobile calls add-on.
€3 for another 60 mins of mobile calls.
You can buy this by text by texting "calls" (without the quotes) to 1745.
How do I buy stuff by text?
