charges
osemudia
I think it's due to your incompetency because every other network treat it as a free number. Otherwise you should have call it for proper investigation. Is a free conference call number.
Damian from 48 already asked you to log a support request so that 48 customer care can investigate for you. Did you follow his advice?
By the way there's no need to open a new thread for every post instead of replying to your original thread to keep everything in one place regarding your query. This is the 3rd separate thread about the same issue.
