Internet Not Working !!!!
ellie_ryan
My internet is not working on my new iphone 5s !! I have bought 5GB of internet yesterday and I followed all of the internet settings provided !!! what should I do ??? I really need the internet to work !!!
dc888
Crew (retired)
Crew (retired)
Are you 100% sure the correct settings are in the phone?
Just double check them as one little mistake will stop it working.
Also ensure you have both data roaming and mobile data switched on.
Damian
This might help when configuring or checking your internet/APN settings:
If necessary post your settings here for review/comment.
ellie_ryan
Turns out I typed in something wrong !! Thank you !!
Glad you got it sorted.
