cant remember my pin
podgy_2014
Ne 1 no customer care number need phone fpe 2moro
There is no customer care number.
All support is online:
But if it's your SIM PIN[1] that you have forgotten then this may help?
I forgot my PIN code
And you can always disable SIM PIN locking on your phone in the security settings.
