16-02-2015 01:57 PM
16-02-2015 03:29 PM - edited 16-02-2015 03:30 PM
Unfortunately not.
You have to wait for your current membership to run its full monthly course and expire before the stacked one will kick in.
In the meantime you may want to look at buying add-ons to tide you over to the end of the membership month if you have used up some or all of your current membership allowances.
Edit: sorry - if there is a stacked membership which has not yet started then try contacting 48 support to see if they can refund you the credit that this cost so you can instead use it to buy add-ons:
08-08-2015 09:18 PM
29-09-2015 01:04 PM
