My 3G won't work
sligo977
Hi there ,
My 3G has stopped working , everytime I go to turn it on it keeps coming up that I have no service , I have been using my 3G in my house and it has always worked perfectly but this morning it just won't work for me.
If you could fix this for me that would be great!
Thanks for your help,
Aine Costigan.
Did anything change on your phone recently?
Software update (seems to be an iPhone - perhaps the update to iOS 9.0 or 9.0.1?), changes to settings etc.?
Check that your internet/APN settings are still correct and that you have some data allowance left:
If both are OK then you may need to contact 48 support:
