abroad
alisonroche
Arrived to Portugal trying to order texts bundles and it says I'm not registered it's like I've been cut off .. i need it sorted ASAP for work purposes
How are you trying to buy the add-ons and what exactly happens?
What are the exact error messages that you get and when?
What make/model of phone?
Do you have a current membership?
Can you connect to a local network?
If necessary manually scan for and connect to a local network.
Can you make/receive calls and send/receive texts?
