Contacting somebody in Fiji
ryanars
He guys just wondering is it possible and if so how can I send a text to somebody in Fiji on the 48 network? Doesnt seem to be working normally!
Thanks in advance 🙂
In that case you just text/call them the same way as normal as if they were still in Ireland and it should work once you have mobile calls/text allowances left.
If it doesn't then chances are the problem is at their end.
48 don't support roaming in Fiji so the recipient's 48 sim won't work there.
ryanars
Actually no but thats my fault as what I meant was that the recipient is with the Vodafone network and I am with the 48 network! Is there any way for me to contact them?
