Data roaming not working in UK
KristianMcN3182
I am in Belfast. I need my google maps app to get back home to Donegal. It worked perfectly on the way up. Now it’s not working. I still have data left and topped up €10 also. I tried troubleshooting, tried sim applications-when abroad etc. still not working. Can you please help me
If you can't get it working then a fallback might be to stop at a service station or other establishment with a WiFi connection and download the necessary maps for offline use.
BTW there was no need/point to topping up your cash credit balance.
