What if...
My question is a bit out of the box....
I had to swap my phone and had to get a nano sim card from 48. It was all sorted, but ater some time I got a new phone that required a micro sim. All sorted again and working fine. Now, here`s my question. I have kept the nano sim card with the activation code and everything and am wondering, if I want to swap to that card, can I just activate the card again to use with the nano slot phone, or once it is switched it is gone for good? I know this sound weird, but I love both phones and if I could clone the card(yah, I know card cloning is illegal lol)to get rid of the hassle it would be awesome, but unfortunately....I`m stuck. Any idea? Thanks in advance.
I'm pretty sure that you cannot have two SIMs active on the same account at the same time.
As such I presume that you have to get support to switch from one SIM to another each time you want to use a different form factor SIM.
But maybe ask support for clarification just to be sure?
I'm in a similar position myself with one phone that takes a mini/regular SIM and another that takes a micro but I'm just using a micro to mini SIM adaptor so that I can use a single micro SIM in both.
