Changing network to Go Conquer
boxingkid
Hello
I have registered as a new customer with Go Conquer.
I am trying to transfer my existing no to Go Conquer.  I have left my old SIM Card in my phone, completed the various questions & finally when I request a security code, am not receiving one on my phone.  (my old contract has been cancelled so it would seem the sim card is no more good).
What can I do ?
You should try again.
I think that the forum was down temporarily earlier for some maintenance.
If you still can't log a support request using the links above then you can email them directly:
[email protected]
If your old SIM is no longer active and you cannot get the porting security code then you will need to contact 48 support for assistance with the porting process:
How do I keep my old number?
Many thanks for your help.
Do you have a phone no. for the 48 support team ?   I cannot trace one on the website ?
I will make contact with them regarding the porting process.
Thanks again.
There is no phone number - all support is done online.
See the links that I posted above - they explain how to contact support.
Thank you for your speedy reply.
I tried the link however it is not possible to type in your enquiry.
It would appear the screen is "down".
[email protected]
