07-10-2015 03:48 PM
Hi, I have just joined 48 and now every time I want to send a message it asks me to roam. I dont understand why it is doing it if I'm sending messeges from ireland to ireland. anybody knows the problem and answer?
16-10-2015 12:13 AM - edited 16-10-2015 12:18 AM
As far as I can tell there should be an Android Lollipop 5.1.1 update for the S6.
But maybe it hasn't been rolled out everywhere yet.
If you go to System settings > About phone > System updates (or similar) it should tell you if there's an update.
I'm not saying that you should update or that it will address this problem by the way.
The warning that you're getting simply seems to be a feature of Galaxy phones and I don't know if there's a way to disable it.
Many phones think that they're roaming when they are on a virtual network (MVNO) such as 48 because they operate on a different physical network (O2/Three).
Some phones have options to disable such warnings.
I don't know if Samsung Galaxy phones do.
If not then you'll just have to live with it.
Edit: I wonder if this is of any use?
http://forums.androidcentral.com/sprint-galaxy-s-iii/185590-roaming-notification.html#post1917478
Uncheck Settings > More settings > Roaming > Roaming guard > Domestic
07-10-2015 04:15 PM
What is the full message coming u Ruiz? Do you get an option to continue?
If you select yes does the message send?
Finally can you let me know what phone you have?
Thanks
Damian
08-10-2015 10:37 AM
Any update on this?
08-10-2015 12:57 PM
Hi Damian,
If i select yes it sends the message and delivers and it doesn't charge me any money for it. (I got the 10 euro deal so it shouldn't charge me for any messege) I just wanted to leave this comment here because i'm worried that it might cause some problems in the future.
08-10-2015 02:39 PM - edited 08-10-2015 02:46 PM
@ruiz wrote:
Hi Damian,
If i select yes ...
Yes to what?
What is the exact message displayed?
48 is a virtual network (https://en.wikipedia.org/wiki/Mobile_virtual_network_operator ) so it is normally required that you have roaming/data roaming enabled for things to work properly even when in Ireland.
This does not involve any additional costs.
There may be a configuration option in your phone or message app settings to disable this warning.
11-10-2015 12:59 PM
15-10-2015 08:04 PM
15-10-2015 08:19 PM
15-10-2015 08:59 PM
15-10-2015 09:17 PM
What version of Android is it using?
You can check in System settings > About phone > Android version.
Is it the latest version available for your phone?
What specific Samsung Galaxy model is it?
