how di i get credit to make calls and text from new york
You'll have to top up your credit balance - most likely online if you are already abroad:
These are the charges for making calls/sending tests while roaming in the US:
Other call charges
When you're roaming in the USA or Canada you'll pay:
Making calls and calling your voicemail€1.99
Receiving calls€1.89
Sending texts39c
Receiving textsFree
*All roaming charges are inc VAT. When making calls, the charge is in a per second increment after the first 30 seconds. Calls received are charged at a per second increment.
(Charges for calls are per minute).
It's pretty pricey so there might be more cost effective alternatives available!
