Something wrong with network/signal
alibxd
Hi can you help me with this?
My messages are not sending they are "sending" for hours but never send and I cannot receive messages, the internet is barely works, I have tried resetting my phone etc, so I think it may be a problem with the network.
Look forward to hearing from you!
Thanks
Ali
Can you make/receive calls OK?
I don't think that there is any general network problem or others would have posted about it.
Maybe no use but try powering off, taking your SIM out, cleaning the contacts GENTLY, putting it back in and switching on again.
If that doesn't help then you may need to contact 48 support:
Hope this helps
alibxd
I just seen this now sorry! It just went back to normal after a few days maybe just a phone glitch, thank you very much ! 🙂
