25-08-2014 04:25 PM
25-08-2014 04:34 PM - edited 25-08-2014 04:34 PM
Your question is unclear and I don't understand the reference to not having an account with another provider.
If the issue is that you are being prompted for the SIM PIN then just enter the one that came with your SIM (and then optionally disable SIM PIN locking in your phone security settings o you are not prompted for the SIM PIN after every reboot). If you don't know the SIM PIN (PIN1) then see here:
If that's not the problem (or solution) then please post back with a clearer explanation of your problem.
28-08-2014 04:52 PM
28-08-2014 05:18 PM
Do you not have the SIM PIN[1] from the packaging in which the 48 SIM arrived?
If not and every time you enter a wrong PIN it still says "2 attempts remaining" or whatever then I don't really know what you can do unfortunately.
Maybe contact 48 support to see if they can help?
02-09-2014 09:42 AM
Alright pal, for some reason it decided to accept my unlock attempts when I used the real PINS off the sim packaging. Odd!
Anyway, it appears that I've now unlocked it with the PUK. Thanks for your help guys. ![]()
02-09-2014 10:13 AM
You mean it did NOT accept the PIN[1] from the packaging?
If so then that's odd but at least the PUK is a way out of this problem.
02-09-2014 10:25 AM
Correct, it did not accept either PIN(1) or PIN(2).
02-09-2014 10:45 AM
If they were definitely from the packaging for the SIM in the phone then that's odd but I think that I've seen that reported before. Not sure why. At least the PUK gets you out of the hole. You could always ask 48 support about it if you wanted further clarification.
