‎27-05-2016 06:33 PM
‎27-05-2016 07:57 PM
If you are porting your number from Meteor to 48 then you leave the Meteor SIM in the phone until you get the security code to complete the porting process.
Once your 48 SIM has been activated and your number has been ported over (if applicable) you use the 48 SIM from then on and the Meteor SIM is redundant.
‎30-05-2016 05:04 PM
