Hi I'm in Vegas and going to NY tomorrow, is there any way ye could improve my coverage, it's so bad
It's a joke and a real let down, I would have moved networks before i left if I knew after putting credit on it that it wouldn't work?? Ye will have to do something or I'll have to leave, it's ridiculous the number of problems I do have with ye!! Thanks
Probably the usual iPhone roaming problem.
See here.
iPhone abroad issue
You may have to try this procedure many times before it works.
Unfortunately this is down to the stupid way that Apple manage iPhone roaming and is really nothing to do with 48 per se.
There are several other problems with iPhones which are also down to the stupid way that Apple manage things (e.g. iPhone, FaceTime, iMessage activation on networks that they don't "recognise"; inability to configure personal hotspot without a hack that allows the required configuration options to appear etc.).
