Sim Card
colin
Hi I move to USA for a while now I'm back in Ireland had my 087 number with 48months was told number not used so disconnected I need my old number back ! And 48 cannot reuse it as they get 089 numbers please please reactivate my sim
If you were away for less than about 9+ months then your account should still work although it may require activation.
If you were away for longer than that (or maybe 12 months+) then your number could have been "lost" and not be recoverable.
You most likely need to contact 48 support directly to get this sorted out:
