29-05-2025
01:34 PM
- last edited on
29-05-2025
01:40 PM
by
29-05-2025 01:42 PM - edited 29-05-2025 01:44 PM
When was it working ok last?
Did anything change in the meantime?
E.g. phone software update, settings changes, factory reset/restore, new phone handset, returned from roaming abroad, etc.?
Do you mean that you have no connection to the 48 network at all - i.e. no signal bars?
If so then if you do a manual search for networks can you see and connect to 48?
If not then what happens?
If you can connect to the 48 network then do any services work?
Calls, texts, mobile data?
If not then what happens when you try to make a call?
Any error messages?
By the way, it's not a good idea to post personal details such as your phone number in a public forum like this where anybody can see and use it.
You should probably edit your post to remove it.
29-05-2025 01:47 PM
29-05-2025 04:28 PM - edited 29-05-2025 04:28 PM
Duplicate posts merged.
There's no need to post multiple times about the same issue.
Especially when I've already addressed your original post.
