SIM card replacement no signal
elcomansh
I order new nano SIM card to replace my old micro SIM card and after activation only 3G show on the top and Internet is working but no signal bars and I can't make or recive calls or messages iPhone 6 and my phone is unlocked ,I tried reset network and phone update and synce with iTunes but no luck till now please help
elcomansh
Unfortunately iPhones seem to cause no end of problems on 48 (and other virtual networks) for some reason.
Are you sure that you got a replacement SIM and registered it as such - and not as a brand new SIM?
All I can suggest is that you put a small amount of credit on your phone and sync with iTunes again as sometimes the iPhone needs to activate on a new network (and a new SIM may be seend as a new network?) and this process can require a UK SMS costing 25c to be sent on a once off basis.
Otherwise contact 48 support in case they can advise:
