Roaming data not working in London & I'm off to Greece soon
SoniaT1597
i am in london, i will travel to greece soon. i have unlimited calls and text but the internet is not working i tried many different ways but it’s still not working
Are you saying that calls and texts are working OK while roaming in London/UK but mobile data is not?
What are your APN settings?
Unfortunately it seems that roaming problems persist for some users.
When it comes to roaming issues the usual advice applies...
