Roaming Charges
cvscribbles
Can anyone help me out? I recently sent a few texts to a UK phone number, and was charged 50c per text, instead of the roaming rate of 7c for the UK. Does anyone know why this is, and if I can get it back?
It costs 25c to send an SMS message to a UK number.
http://www.48months.ie/membership-plans/international-calls
A single SMS message can contain 140 characters (or fewer if "extended" characters are used).
https://en.wikipedia.org/wiki/Short_Message_Service#Message_size
Long messages can use more than one SMS.
For example a 200 character text to a UK number would use two SMS messages so would cost 50c.
The cost of sending a text while roaming abroad (7c) is irrelevant here if you are still in Ireland:
Did that help?
Thanks for your help, hadn't seen the international charges page. I'll go have a look now. Thanks again!
