Replacement Sim
meadbhmcs
please help, got my replacement sim and cant seem to register it! 😞 have tried entering the code and everything but keep getting this message "Your account has been de-activated. Please register a new SIM if you wish to re-activate your account"..                          would appreciate help thanks a million! 🙂
Any use?
http://community.48months.ie/t5/Need-Help/REPLACEMENT-SIM/m-p/1296#M420
7 REPLIES 7
Any use?
Hey 🙂
That sounds like a techinal problem alright..
My best bet is to log in to your account on here and raise a ticket and explain the problem. Those techies guys should help out no problem.
I hope it gets fixed soon 🙂
markstrong
Hello! I have the same problem now and can't get on to any sim registration / replacement registration page without being told I don't have access, or that my account has been de-activated
Can you delete 48 cookies or try another browser/computer just to see if it works there?
You might need to log a support request to get 48 to help:
http://help.48months.ie/anonymous_requests/new
support@48months.zendesk.com
Won't let me activate a replacement simple. Plz help
What happens?
Any errors?
You may need to contact 48 support for assistance if the normal procedure doesn't work:
Any update?
