Reception
kerpackie
Can somebody help me with getting reception on 3gs iphone?
What exactly do you mean?
Did you SIM ever work at all?
Can you get any signal/bars?
Can you search for networks, see 48 (or O2 if 48 isn't listed) and connect?
Do you have data roaming and 3G enabled?
Do any services work for you at all - e.g. make/receive calls, send/receive texts?
Do you want internet access?
If so then you'll need to configure your internet/APN settings - see here:
http://community.48months.ie/t5/Need-Help/one-plus-one-mobile-data-settings/m-p/33610#M11885
You need to clarify what the problem is.
No service keeps coming up, were I live and everyone else in the same house has reception.
Yes it does work near towns and citys.
Can search networks meteor, vodafone and 48 appear, when I try to connect "Network Lost , Your selected cellular network is no longer avaible. You can choose a different network in Settings."
I dont have data roaming or 3g enabled.
Yes can recieve txt and calls.
have you tried your SIM card in another unlocked phone yet?
Also try reseating the SIM in the phone.
If you still have problems and it doesn't work better in another unlocked phone then you may need a new SIM.
