Please help me
daylepower
I purchased €10 credit and i put it in and my balance changed to €10.80 and as soon as I went to buy my guideo membership it wouldn't go through, so I looked at my balance again and it was only 80c? What can I do? Or what happened please get back to me
6 REPLIES 6
My guess is that you DID manage to buy Guido membership but it has stacked to kick in when your current membership has expired.
A new membership does not start immediately if a current membership still has time left of its monthly period to run.
If you use up current membership allowances then buying a new membership is no use (until the current membership expires) as you don't get the new membership allowances immediately.
In that case you need to buy add-ons to tide you over to the end of the current membership month.
Your online account should clarify:
https://www.48months.ie/my-48
Check what it says about...
  • Your current membership type and expiry date
  • Your next membership and start date under Membership Planner (if applicable)
Also check your My History page:
http://www.48months.ie/my-48/my-history
and check what recent payments/topups/purchases are listed there.
daylepower
Nope it didn't help thanks anyways
What exactly do your My 48 and My History pages say?
daylepower
It just says the last time I topped up but not today's top up
Which page?
And what exactly does it say?!?
You probably need to contact 48 support at this stage.
Do that here:
Any update?
