Phone says I'm roaming
I had an iPhone 4 and had no problems with 48.yesterday I got a Samsung galaxy s3 and I know the network was down but it's back now and it says I'm roaming so I can't use my internet can anyone help me with this
Regarding the "roaming" issue see here:
http://community.48months.ie/t5/Need-Help/Phone-shows-I-m-roaming/m-p/2250/highlight/true#M684
If data/internet access is not working make sure that you have the option to use data while roaming enabled. If that doesn't fix it then you may need to review/reconfigure your internet settings
Internet Settings
and if that doesn't work contact 48 support for assistance.
Internet Settings
