Phone Unlocking
stephanieanne
Hi! I made the stupid mistake of transferring my number to 48 BEFORE unlocking my Meteor phone (Nokia Lumia 520). I'm wondering if anybody knows anything about how to go about unlocking it without calling from my Meteor sim as it is no longer active. Thanks!
Hi StephanieAnne.
In any big town there should be a computer/cell repair shop; in which you can usually get your phone unlocked.
The price for this usually sits around 20euro though!
Can you get it unlocked officially through Meteor?
If not then you should be able to unlock it "unofficially" online or in a phone repair store as mentioned above.
