11-09-2013 08:22 PM
12-09-2013 01:45 PM - edited 12-09-2013 01:46 PM
OK - I don't really know what the issue is so. Is this of any use?
https://discussions.apple.com/thread/4417148?start=0&tstart=0
If not you may need to log a support request to get 48 to help you.
11-09-2013 09:56 PM
When you say "away from home" do you mean roaming abroad? If so you will need to connect to a wifi hotspot as data roaming abroad is not supported.
If you mean away from your home but still in Ireland then I presume that sending emails works while you are on your home wifi network but not when you are out and about on a data connection? In that case I presume you have a data package (membership or add-on) and have your internet settings configured correctly?
The email settings themselves are whatever your email provider specify and have nothing to do with 48 per se.
12-09-2013 01:16 PM
