Number swap
nishahayden
Okay I joined with 48 today and I swapped my old number over but then realised I need two numbers one for work and the other personal use so how do I swap numbers again from my ole one to the new 48. Number thanks
If you want two numbers on 48 then you'll need two accounts, two email addresses, two SIMs and two phones or a single dual SIM phone.
If you mean that you want to replace your current number on 48 with another then you just submit a new porting request to get the second one transferred over. In that case the original number will be lost.
