Nothing is working!
lalufoley
My texts, calls and 3G are not working. They stopped working last week so I thought maybe I had been suspended without warning but I topped up my membership last night and it's still not working. Please fix this as I do not have wifi and have no way of contacting anyone at all. Please help quick
What does your online account say about your membership status, expiry date and allowance balances?
Do you get a signal/connection to the 48 network?
If not can you manually scan for networks and connect to 48?
I wonder if, after the outage the other day, you need to reactivate the iPhone on the network which would need at least 25c cash credit (to cover the cost of a UK SMS that gets sent automatically) and might also need a reboot and/or a sync with iTunes.
Alternatively contact 48 support and ask them for advice:
Hope this helps.
