Not registered on network. urgent.
steve88n
I changed from Vodafone to 48 today. I registered, bought a membership, entered apn manually and it came up. I had coverage and tried to make a call but it said not registered on network. It now keeps jumping on and off the wifi and one minute there is coverage, the next it's gone. I tried the sim in another 48 registered phone and it wont work in it either. Please help, I need my phone for work.
Try gently cleaning the SIM contacts and see if that helps.
Try manually scanning for networks and manually connecting to 48.
If that doesn't help then you'll probably need to contact 48 support for advice:
