Not recievivg phone calls or texts
jill_hanlon
I have an iPhone 5 and I'm not recievivg texts or calls and my phone often doesn't actually ring if someone tries to call me they just get user busy please help
Did incoming calls/texts ever work OK?
If so when did they stop working?
DId anything change on the phone just before you experienced this problem?
Do they not work for some or all users?
Can you make calls/send texts?
You might need to contact 48 support for assistance:
jill_hanlon
Idk when it started doing this and idt anything has changed and yeah I can make calls and texts
You'll probably need to contact 48 support so.
Use the link that I posted above.
Did you get this sorted?
